footin616 »
https://forums.nicoclub.com/footin616-u64825.html
Sun Sep 02, 2007 12:31 pm
I can drive my car but I have no electrical inside of the cabin. I have a S13 with a black top. None of my gauges, interior lights, radio, seatbelts, etc have power.
Headlights turn on but do not flip up, if that helps at all.
It used to always do this but the power would come on to the gauges, etc after I tapped the throttle a little. This does not work anymore. Is there a wire that bring all of the power into the cabin of the car that I can check. All fuses are fine both in the kick panel and in the engine bay.
It seems to be some kind of a power problem becuase my test light is not lighting up when I poke around in the fuse block.
