Help electric problem
keiths240sx
I have a 1989 240 and if I run the radio wipers and heater at the same time the radio will turn off and about 5 min later the car will die. I went to a local parts store and checked the battery and it was a good battery just a low charge. Can anyone help?
S13Joe
Car: 92 Coupe
Check fuses?
carkook
Sounds like your alternator. I would check all the bolts and wires going to and make sure they are tight. If the car still continues to die take the alt. otu and get it tested.
freakyjason
Car: 1990 240sx
DirtyGhettoKids wrote:Check fuses?
And grounds? Could def be your alternator though.
