e_c »
https://forums.nicoclub.com/e-c-u14217.html
Mon Oct 03, 2005 6:27 pm
i dunno why it was dead.... i took my car to get it aligned today after i put some nice goodies on it from spl, after the guy was done aligning it, it needed to be jumped, then he test drove it to make sure it was aligned, maybe 5-10 min... then he parked it and turn it off, i paid, maybe 10 min later i try to start it again, no luck... had to be jumped again... this was all before i put the faceplate to my deck on... deck on, listining to music, everything is fine.... put my foot on the brake to shift into reverse and leave, my sub skips, roll though the parking lot, hit the brakes again, same thing... i stop take a look at the power connections at the amp, all good, i drove home without the face plate on... when i would hit the brakes, the light in the clock in my hud would dim, then come back....
edit: also note that no hud lights are on, and i know the battery light works, cause a bit ago, the alternator belt broke, and the batt light came on
Modified by e_c at 6:01 AM 10/4/2005
