Hi I'm new to the site, maybe you guys could help me.I'm in the process of removing my ECU from my 02 Maxima. I located and disconnected, but I'm not able to remove it from it's bracket.
I saw two plastic clips,
But there are also 2 screws one on each side of the ECU. I manage to remove the one screw from the picture, I just can't get the one from the opposite side.
Is really tight in there, makes it hard to work on there.It seems I will need to take the Glove Compartment out, to get better access to the ECU.
thanks.
