If you can't get into the diag. mode, then there is a good chance the ecu is fried. Have you tried to swap the stock chip back in to see if the diag mode works? You may get lucky and only damaged the eprom chip.Chase300 wrote:I spoke with the supplier and he said if i installed the chip backwards i would fry it. Does this make sense?
