HELP! EBRAKE WONT DISENGAGE
ivorton23
Car: 1996 Nissan Maxima SE 5 speed
left my car parked for one while it was storming here in SD and when i took it out for spin today the ebrake wont disengage. the lever is fully in disengage position but my right rear wheel is locked up. its below zero so i believe the cables or sumthin is frozen. what do i do? my hand brake lever feels loose too.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The park brake actually engages both rear brakes, so I suspect you just have a stuck cable for the right side. If you pull the tire off, you can easily remove the park brake cable from the brake caliper. That won't affect your normal brake function (so the car will still be safe to drive) but it will get the brake to release if the cable is indeed stuck.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
The Parking Brake has 3 cables - 1 for the front and 2 for the rear (LH & RH). The rear RH cable is probably binding/frozen. Remove the RH rear wheel and then unhook the parking break cable. Replace/lubricate that cable ASAP.
