Help downgrading my power antenna
thomasjamal
Car: 93 coupe
So I've searched through a bunch of threads and can't really find anything on what I want to do.
I want to loose the 8 foot power antenna (maybe an exaggeration) and replace it with one of the various short antennas available on ebay and in auto parts stores. What I'm not sure of is if I need to remove the power antenna motor and buy a bracket/connector or can I simply screw the short antenna onto the top of the power antenna, since I've already removed the mast? If so, I assume I could simply unplug the wiring harnesses from the motor but leave the antenna itself connected and have a normal signal?
I know I can't be the only person who's wanted to do this. Somebody help me out.
daves240sx07
Car: 1993 240sx fastback
1991 240sx fastback
2005 Subaru outback
I used a Saturn's antenna(it was what was around at the time).Made a bracket for it.The antennas top is removable and u can put a short one on if u like.Removed all of the stock power antenna.
thomasjamal
Car: 93 coupe
So I can grab a manual antenna receiver off pretty much whatever is sitting around at pullapart?
kouki munster
Car: 97 base 240
Just find a factory non-power antenna. I keep wanting to put a fox tail on mine.
motoman399
Car: 98' wrecked (RHD coming soon) 240
i have 2 or 3 s14 manual antennas ill trade for power antennas.
94_240sx
Car: 94_240SX
S2000 antenna fits perfectly on s13 coupe. Remove the mast and screw in.
motoman399
has to be a manual antenna to start with. you cant screw anything into a power one. there has to be threads to go into.
Warped161
Car: 90 s13 the never ending project
I shaved mine and put this in the window, it works pretty good.
thomasjamal
Car: 93 coupe
I'd love to shave it if I had any body work skills, but I don't.
I'm looking for a factory non-powered antenna. I'm not sure how a S14 antenna would fit on my S13 coupe. I do have the power antenna uninstalled now. The mast is broken, though, so I'm not sure if it works or not.
If all else fails I think I'll go to pull a part and just look for something that would work.
KoopaTroopa
Car: 1991 black hatch
I'm thinking about shaving it off and putting on a small shark fin antenna, not sure how it'd look though. I'm thinking of it on a hatch with a lip spoiler at the window though
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I need one, my trunk lock and antenna are already shaved.
Warped161
^^^ the trunk lock passes though the center plastic piece how did you shave it?
kouki munster
Car: 97 base 240
Coupe.
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
Just pull the whole motor and antenna out, tape up loose connections, then put an autozone antenna where the old one was... Thats wut i did an it works just fine.
Warped161
kouki munster wrote:Coupe.
