Two-Forty »
https://forums.nicoclub.com/two-forty-u2538.html
Wed Nov 13, 2002 7:44 am
For the doorlocks, I suggest you save about 200-300 and get an alarm for you car, that way you don't have to spend the money on fixing the door cylinders, plus you can get added security of an alarm. If you don't have power doorlocks you can get them added about 20-30 a door depending on where you go, we charge people 25 for each door.
About your hatch, maybe your cable is not taught enough to pull the lever itself, check to see if your cable that runs back to the hatch is taught.
