toofordee wrote:ive tried searching but couldnt really find an answer to my problem.
i dont know whats wrong with my car. when i woke up two days ago, my car wouldnt start. first it started up then died right after. i tried it again and it would just crank. i then cheked the fuel pump fuse, it was blown. so i replaced it and tried to start it. i still wouldnt start. after a few time the fuse was blown again. so i put a 15 fuse instead of a 10 fuse. (i didnt have any at the time)..it diddnt blow that one. so after searching i found out my pump was bad. because i couldnt hear my fuel pump operating the first 5 sec on the ON position. so i replaced that, but then it still wouldnt start. still just crank but no life to it. checked for sparks on my plugs and wires and they all was working fine. i found out that i dont have any fuel pressure going to the injectors, by cranking it with the fuel filter off.
My question is what could this be? and how could i fix it? and get it to start..i have a new fuel pump and the fuel pump relay sounds like its working. caus i can hear the clicks when i turn my key to the on position. any body had this problem b4...please i need to get my car up and running.
just got a ka24de from a pick n pull for 153. dollars.i put a socket on tha crank and tried to spin it and it was a little too hard for me to spin.does that nessecerily mean it aint gonna turn over?or could it be that they drained tha oil b 4 they set tha car on site?if so, i aint gonna rip it apart. ill take my chances. tha motor looks good n clean, wit no leaks or blown seals so thats why i got it.hit me up. . .
