On a lift witha transmission jack suppporting the transmission, we hope.Cezar718 wrote:... i just need those damn bolts.....
I knew it was a loooong extension but not a 3 footer.maxnix wrote:I am sure you have read in the previous posts about transmission removal that a 3' extension is required.
30" might get it, but all references I can recall said 3 ft. 2 ft. wont', as I recall. Can't imagine doing this on the floor!goody94q45 wrote:
A lift would be nice for a lot more than pulling a transmission. I've taken my car to the shop a few times not because I couldn't do the repair but because I don't like working under anything for any length of time that's supported by jacks. I worked for a mortuary during my first couple of years of college and have a few bad memories.maxnix wrote:Can't imagine doing this on the floor!
No. If the transmission member is still in and the motor is still on its mounts you won't be able to see the bolts without a mirror and a light.Cezar718 wrote:so i would come from the back of the transmission with the 3 foot extension.. would it be easy to see the top bolts since the transmission is leaning down because the driveshaft is out?
Also, the earliest ones never were moved from Infiniti General.anlasak wrote: The search function takes a little while to get use to, so I use to find it easier to just read every thread in the associated forums, (IOM/Q45/VH&VK).
Well it definitely isn't going to be easy whatever way you choose. If you read the Factory Service Manual, you'll see that Nissan intended you to remove the engine/transmission from the Q45 as a single unit and seperate the 2 outside of the vehicle.Cezar718 wrote:transmission member is out and the motor mounts have been loosened up from the bottom.. still hard?
Calm down Maxnix. There's no need to wag your finger at me.maxnix wrote:Also, the earliest ones never were moved from Infiniti General.
Congratulations to Anlasak for getting it!
(Now if he would just complete his profile!)
Learning about your car will save you time, money, aggravation and it will perform better. It ain't about the dubs!
Great!anlasak wrote:
I'm updating my profile, which is why it is currently blank.
Stick a pry by in the teeth of the ring gear and brace it on the transmission guide pins/ dowels or something steel ran through the bolt holes of the bell housing.Cezar718 wrote:how do i keep the torque converter from spinning while taking off the bolts?
From Joe. Call anyone there as KS and plugs are marked way down until after tomorrow.Cezar718 wrote: where would i get a kit of under plenum hoses?
