Help Do-Luck install
innocents13
Hi, I'm new to this forum.
Has anybody installed the Do-Luck rear tension set and floor bar before. I installed the rxb already, but I am having a hard time fitting the actual hoop of the tension gauge in. This is going on a 90 Nissan 240sx.
By reading the instructions, it tells me to mount the bottom to the seatbelt anchor hole. But when I do that the hoop hits the roof and crushes the B-pillar. The top hoop has to be set at the shortest setting to even get the top hoop into the floor support bars. grrr. Has anyone installed this tension set before? I have a moonroof on my car, it that helps. Is the JDM fastback different in anyway for this bar to go in?
And just to let you guys know, the floor mounts are not flat, they are bent like this " __/'''''' " (haha I dont know if this helps). I also understand this is not a true roll cage, I bought it because it was a good deal and used (from Japan)
Thanks in advanceRob
MarkEmark
Car: fully-built '95 240sx KA-T
OT--But how do you like the RXB? How hard was it to install? Worth the $350? I've heard people who swear by it and people who think it's a waste. What are your current suspension modifications?Thanks...
