HELP!!! Display screen will not turn off
08M45NC
Car: 2008 M45
When I shut my car off my display screen for NAV, radio, etc. stays on. When I restart my car I get this message: Configuration failed because CONSULT is connected, please disconnect CONSULT. What is this?? Does anyone know how to fix this.
:confused:
I have a 2008 infinti M45
Ilya
Welcome to the forum.
CONSULT is the diagnostic tool that dealers and shops plug in to your car to find issues...weird that the A/V unit thinks it's connected...or did the dealer leave it plugged in? lol.
08M45NC
Car: 2008 M45
No it hasn't been to the deal in while, since the last oil change...so 3k miles ago. This just happen out no where
Ilya
Search this forum on how to enter diagnostic mode...may be able to find something in there to test the system.
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
Hooking up consult will always give you a system test and black screen on the display. That's a weird issue you're having, I've never seen it. Try disconnecting the battery for about 15 minutes to do a forced system reset and see what happens. Kind of sounds like the BCM isn't going to sleep when the ignition is shut off.
szh
Car: 2018 Tesla Model 3.
Also check to see that you do not have something connected to your OBD-II port ... (or that the connector does not have shorted wires in some way).
Maybe your significant other stuck in a tracking device into that port! :chuckle:
Z
Blakkzm45
Car: 2008 m45x
Did you ever find a fix to this issue im havin the same problem
