Help Diagnose This...
RayRandolph
Car: '90 Q45 60k Toxico Blues, sway bar, Michelin Pilots, '94 Q45 rims
OK, I have a '90 Q45 that did the following:
In normal driving, the brake light was coming on faintly. Then at idle it would come on brightly along with the ABS light; after a few seconds the message window would read "Battery Charge Low".
Rev engine, message disappears, ABS light off, still faint brake light.
Batt is 2 yrs old, in good shape.
Dying alternator? Bad voltage regulator? Bad battery?
Dennis? Anyone?
Thanks,
Ray
crubio
Car: cars, karate, reading
I had the same problem with my 90 Q last year. It was the alternator. You should probably replace the battery also. Good luck
crubio
DAEDALUS
Car: 1990 Infiniti Q45
I agree--alternator. Such a funny string of symptoms, I wonder if that was intentional?
aaacomp
Car: Family, church, Computers, Cars
had similar problem on 91T ,,, Alternator....:thumbup
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
I had the same problems. Replaced the battery and alternator. Cleaned all grounds-checked all fuses. Turned out to be the positive battery cable wiring harness. $800 for a battery cable seemed a little high.
Q45tech
If you saw the condition of most battery cables and terminals on customer cars and their failure to keep the engine compartment clean [and non corroded from allowing batteries to remain installed too long].........beatup cracked battery trays allowing the acid to dribble down on relays and cables under the battery ........you would want to charge them $8000 as punishment......$800 seems like just getting probation instead of serving time!
Remember Cleanliness is next to godliness so few [engine compartments] get any prayers.
OLU40
Car: Infiniti's Martial Arts, Science, Reading, Sports, Computers, Electronics WOMEN!
SAME SYMPTOMS HAPPENED TO ME LAST NIGHT. jUST CHANGED THE REAR SHOCKS (TOKICO BLUES). SUCKS. I JUST BROUGHT THIS BATTER (SEARS DIE HARD) 2 MONTHS AGO. IS IT NECESSARY TO CHANGE THE BATTERY. THERE SHOULD STILL BE SOME SIGNIFICANT CHARGE LEFT.
90Q45blue
Car: 2006 Honda Accord EX-L
If the battery/alternator deal didn't fix the brake light coming on try putting more brake fluid in. Mine does that all the time when the fluid is low.
Q451990
I've had to replace my battery on average every 23 months... I know this because it has a 24 month free replacement warranty :) This car is hard on batteries - so I wouldn't rule out the battery either! You might want to have the system load tested to see if the alternator is working properly. NEVER go with a non-oem alternator - they have a very poor track record.
Heath
getatu
Car: wine/women cars and song
just had a problem like that last night driving the radio kept cutting off radar cutting on and off headlights when real dim shut it off and it would not start new battery so i knew it was not that....got it started inthe morning disconnected the battery and it was the alternator....anyone know of a place thats cheaper than 350buck which is what the dealer charges out in massapequa/1997 q45t
getatu
90Q45blue wrote:If the battery/alternator deal didn't fix the brake light coming on try putting more brake fluid in. Mine does that all the time when the fluid is low.
that was going to be my next question if off brands are any good
Q45tech
Off brand rebuilds are very very bad they just clean up the old units and maybe install new/used bearings.....they disassemble hundreds and reuse the good worn parts in various units to make a good one.
We tried every rebuilder in US but had too many warranty failures in 12months 12k. We were losing our shirt trying to save owners money!
If you want to gamble try a junk yard unit they may last longer than most rebuilts......
If $350 scares you .........are driving the wrong car? This is an area you don't want to skimp on!Always install a new Quality battery when changing the alternator or you may overtax the new alternator in trying to charge a bad or weak battery.
aaacomp
http://autoexpress.safeshopper...tm?75for $158 plus core.. A year and a half ago I had one go out and I called Infiniti and ask them how much to replace it $1000.00 parts and labor. I bought one for $190 and put it in myself .................:thumbup
getatu
Q45tech wrote:Off brand rebuilds are very very bad they just clean up the old units and maybe install new/used bearings.....they disassemble hundreds and reuse the good worn parts in various units to make a good one.
not afarid to spend the $350 just trying to see whats out there:thinker
reggiegsd
Car: '94 Q, '73 240Z
I've had good luck with some of the local re-wind shops with alternators and starters on other cars (not the Q). Ask around the independent repair shops to find out who is producing the best rebuilds locally. These guys wil all have the same complaints Q45 gave. Cheap price normally equals shoddy work.
Some rebuild shops do excellent work. New bearings, re-wind the rotors and armatures, new electronics. Often these hand-made rebuilds are more reliable and more efficient than the factory unit.
You will have to hunt to find these shops. They are NOT the norm.
Once you find one of these shops, you will never use anything else.
The shop I use in Tampa took a Hitachi alternator from an early Zcar (all of 45 amps) and rewound it to produce 75 amps. It is eight years old and still running.
DrewQ45
The work involved in replacing the alternator makes it the kind of task you don't want to repeat anytime soon. I replaced mine early last summer with a dealer unit. I imagine one would pay through the nose to have the dealer perform the labor.
..Drew....
getatu
DrewQ45 wrote:The work involved in replacing the alternator makes it the kind of task you don't want to repeat anytime soon. I replaced mine early last summer with a dealer unit. I imagine one would pay through the nose to have the dealer perform the labor.
..Drew....
labor is 2hrs at 85bucks per..massapqua,li
Q45tech
Agree you can find specialty shops but they won't want to mess with it unless you bring them all the parts as only the Q uses the 110 amp alternator and they would have to order everything from the dealer who doesn't keep the bearings or diode pack or regulator in stock because they just sell the factory remans.
By the way I visted 7 shops around ATL trying to get someone to rebuild an alternator when they saw it no way unless I brought them 2 sets of all parts.........the labor would have been around $100 plus parts maybe another $100.
If you can get the parts why not. If you can change it why not.
It's just thant most national chain remans are junk [lowest bidder]
