anti_flag_army »
https://forums.nicoclub.com/anti-flag-army-u50284.html
Mon Feb 14, 2011 8:56 pm
Hey guys, so my friend just picked up an 89 coupe that needed a little love, and we have been going through it fixing various issues. One we cant seem to get is the rough idle with a slight miss. I will start out with what I have tried, and hopefully you guys will point out something obvious that I missed.
First we started with the error codes and gave us code 45 (leaking injector) I swapped some known good injectors and got the code to go away. (idle still bad)
Next we swapped o2 sensor with no change. Did the coolant temp sensor since when searching a few people mentioned that. Next were the spark plugs, the old ones were really black, swapped in some fresh ngk's. I cleaned the battery terminals to ensure a solid connection. Checked for vacuum leaks and couldnt spot any.
All of this and still we have a bouncing idle (and it smells pretty rich also) I suppose the next thing is to do a cap and rotor +spark plug wires. What else am i missing?
