Ok, the vid is uploaded now. I'm not sure how much data you guys can gather from it but it's a start I guess. The misfire/detonation is really noticable in the vid, a lot more than in person. I also forgot and had the ecu in valet mode so 3k is all it went up to. Before in active test mode when I kill injector 2 it seems to have little to no effect versus the other injectors on the R bank.
What you can't see is the the cas/rpm reading drops off erraticly from 2000 to anywhere between 300-100 and one time I saw 13 when the playback is slowed down.
I'm downloading ecutalk as I write this so I'll post a log of that when I get it. Hopefully the crappy pop-up filled hosting site I chose will host it properly.
I don't even want to run it anymore in fear of catastrophic failure before I even get to run it for a day...
http://www.youtube.com/watch?v=t84XxYJMCkM
