Help Deciding on tires
Soccer4555
Car: 2011 G37x Sedan
Hi All,
I'm hoping you can help me pick which tires I should buy for my summer set, I already have Bridgestone Blizzak WS80's mounted on a separate set of rims for the winter.
I have a square setup of 17x7.5in wheels for the summer.
I'm deciding between these two tires. I'm looking for better steering feedback, confidence, and handling/stickiness for corners.
Pilot Super Sports are not an option as they don't come in 225/55R17 or 235/50R17 and 235/45R17 would throw off the spedo by too much and mess with the AWD system
Ultra High Performance All Season
Michelin Pilot Super Sport A/S 3 $192 per tire
225/55R17
vs
Max Performance Summer Tire
Bridgestone Potenza S-04 Pole Position $218 per tire
235/50R17
*These will be -1.5% less in diameter than the stock size
equatorial
Car: 1993 BNR32
I had a set of Pilot A/S 3's on a Fiat 500 Sport. Best part of the car.
You may also check out the Ultra High Performance All-Season Potenza RE960AS Pole Position RFT, which do come in the size you need.
If you grab 'em quick, the Potenza S-04 Pole Positions are currently on special $127 at Tire Rack
NicoLoco
these threads mentioned the tires you're deciding on, you may want to check it out:
post6643188.html?hilit=Bridgestone%20Potenza#p6643188
post6676427.html?hilit=Bridgestone%20Potenza#p6676427
RiffRaff35
Car: Blackedout
Hi guys. Any recommendations on tires with a rim guard, all season run flats? Looking to get 285/30/19 and 245/35/19. Hopefully there will be Black Friday deals coming up for the holiday on tires.
Miguel Reid
Car: 2015 Nissan Armada
RiffRaff35 wrote:
Wed Oct 28, 2020 6:42 pm
Which tire did you end up getting?
RiffRaff35
Car: Blackedout
Miguel Reid wrote:
Mon Jan 11, 2021 11:09 pm
I went with the Yokohama Advan A/S+. They were cheaper then the other choices I had in mind. Took a chance on the Yokohamas all seasons and I'm pleased with them. It's a fairly a new model tire. They are firm with a good grip but a little softer on the ride. I have coilovers with a stiffer suspension.
