Onslaught31 »
https://forums.nicoclub.com/onslaught31-u66050.html
Sat Jun 16, 2007 5:21 pm
If you love your maximas, just remember they're (more or less) the same car, just different bodies. Here's how I'd rate the G35:
Reliability: Engine is top notch. Just look at the list of awards, including most reliable engine. Little things might need tweaking, but that should be taken into account when you buy a high(er) end car. Shouldn't run into any repair (excluding maintenance) that costs more than $200 within your first few years.
Comfort: On this subject, get the newest possible model you can afford. The launch year (which I own) is still an amazing car, but they didn't have owner feedback or experience to really make an interior that you want to sleep in. The newer models are streamlined, beautiful, elegant, and comfortable. '03-'04 feels like you're in a racecar: less comfort, more oomph. '05-07 they've switched it. It's no longer a comfortable race car, it's a really fast luxury car.
Performance: Every model is extremely fast (for day-to-day standards). Doubt you'd notice the difference in power from an '06 to an '07 for instance, so don't let that change your decision. I've personally taken mine to 145 mph, and it still didn't want to back down. The power will translate to much higher maintenance costs though. Expect to replace brakes on a more regular basis (unless you upgrade) or the rotors will get destroyed too. It also devours oil like a beast. Even with synthetic (life of 6k miles), I'd change it about every 4k or so. Air filters are another big concern. Consider upgrading intake to an oil filter, which is cheap, and washable! Lastly, most people forget about it, but transmission flushes are a must. Probably about every 15k miles.
Lastly, it's more cost effective to get an aftermarket GPS, they work better and cost less. If you have a few extra bucks, get it wired professionally to the car battery so you don't use cigarette lighter, or see cables.
Sounds like a list of negatives, but overall the car is amazing, definitely worth it in my opinion. Hope this helps
