2006M45Sport »
https://forums.nicoclub.com/2006m45sport-u208990.html
Mon Oct 01, 2012 6:59 am
I have a 2006 M45 Sport and my RAS/VDC/Slip lights came on (just while driving - nothing happened). I thought I needed brakes, so I replaced my brakes rotors and brake fluid. BTW - I didn't really need brakes, but my rotors were warped so I replaced everything. The lights stayed on. I took it to the dealer and they tried everything (so they said). They have my car for almost 2 months and replaced ICC distance sensor, abs controller, brake light switch, RAS control module, instrument cluster and recalibrate the RAS position sensors. Nothing worked, so they said it was my aftermarket remote start that was the problem (it has been in there for over a year). I took it back to Best Buy to have it removed and the technician said he seen nothing wrong w/the system or the wires. The dealer said this should fix the problem and the lights will go off. The lights stayed on. I brought it back to the dealer and they couldn't reset the lights and they said the remote start system must have ruined my wiring harness and I need a new one. $3500. If my wiring harness was bad, wouldn't other lights come on? Where do I go from here?
The codes are:
C1137 - RAS CIRCUIT - TIME 0
C1145 - YAW RATE SENSOR - TIME 0
C1185 - ACC CONT - TIME 0
C1A04 - ABS/TCS/VDC CIRC - TIME 2
C1A18 - LASER AIMING INCMP - TIME 2
C1A26 - ECD MODE MALF - TIME 0
C1911 - MOTOR VOLTAGE (LOW VOLTAGE) - TIME 0
C1929 - VDC - TIME 0
B2551 - STEERING LOCK UNIT - TIME 111
B2553 - IGN POWER CIRCUIT - TIME 111
B2554 - ACC POWER CIRCUIT - TIME 111
B2559 - PDU - TIME 111
B2560 - START POW SUP CIRC - TIME 111
B2118 - TILT SENSOR - TIME 67
