HELP!?!?! Cylinder 1 not firing!?
Reaper
Car: 96 & 91 240sx
rb25det series 1 in a 96 s14..cyl #1 is not firing for some reason?
I have: checked wiring, checked spark (and changed the plugs), checked the coil pack, checked and replaced the ignitor chip, maybe some other things that i am too flustered to think of right now...
I have not: checked the injector, checked/adjusted timing
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
pull off those timing covers and check the timing marks.
kjlindgr
Is it not getting fuel or not getting spark or both?
Carl H
if it has spark its a fuel issue.
Reaper
Car: 96 & 91 240sx
ok, i don't have time to get to this until saturday, but i will check the timing marks and de pressurize the fuel system and pull that injector to see if that's it.
Thanks for the help everyone!!
Carl H
the easy test is to just pull the injector clip off if it doesnt change exhaust note then the injector is suspect.
Reaper
Car: 96 & 91 240sx
Carl H wrote:the easy test is to just pull the injector clip off if it doesnt change exhaust note then the injector is suspect.
I did the same thing to test the coil pack and that didn't change the exhaust note at all.....
Carl H
if you swap coils around with say cylinder 2 and cyl 2 dies then its the coil, else its the injector.
Reaper
Car: 96 & 91 240sx
Carl H wrote:if you swap coils around with say cylinder 2 and cyl 2 dies then its the coil, else its the injector.
awesome, i did exactly what you said. I swapped coil #1 and #2 last week and #1 was still dead. so i was right it's narrowed down to that damned injector.
Eikon
Car: 71 240z, 93 Supra TT
you might want to swap spark plugs between one and two as well.. just to rule that out.. I know you said mentioned new plugs in your first post.. . but you could get a bad plug?.. Just be sure so that you can move on to the next thing...
You could very well have a clogged fuel injector.. try swapping the injectors from 1 to 2 and see what happens then...
Carl H
sometimes if you give it a good rapp on the side it can free a stuck injector, but its wholy possible that its just dead.
240love
Car: 240
kool...im having the same issue right now..and mine seems to be the injector also
Reaper
Car: 96 & 91 240sx
Carl H wrote:sometimes if you give it a good rapp on the side it can free a stuck injector, but its wholy possible that its just dead.
well i replaced the #1 injector last night and NOTHING changed, i'm soo pissed, i have NO idae wtf to do now.... I'm ready to just give up
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Did you do a compression test? Maybe your #1 cyl is bad. Happens.
gawdzilla
Car: none
might be the yellow vinyl on your headlights... j/k
leakdown or compression test on cylinder 1 and compare it to one that you know is good.
nizmo zilvia
I like that yellow vinyl. :P
Carl H
it possibly might have fried the driver for injector 1?
Reaper
Car: 96 & 91 240sx
nizmo Z ilvia wrote:Did you do a compression test? Maybe your #1 cyl is bad. Happens.
i did a compression test, and #1 wasn't very different from the others maybe 2-3 lower.
Carl H wrote:it possibly might have fried the driver for injector 1?
i don't even know what that means??? Is there a fix for that?
as for the yellow vinyl it has been removed (i just did it becuase it was different around my area, now everyone is doing it so it's gone now, lol)
Booztd 3
Car: 1990 Nissan 300ZX TT
Reaper wrote:i did a compression test, and #1 wasn't very different from the others maybe 2-3 lower.
You might look into finding a replacement for the igniter. My igniter died last week and it was only not firing cylinder 4.
Reaper
Car: 96 & 91 240sx
The ignitor has been changed also.....but I'm not sure what ignitor is on the car right now, i'm going to take a pick of it and post it up here tonight.
Reaper
Car: 96 & 91 240sx
sorry i didn't get to touch the car last night, i'll post that pic when i get home from work today.
