HELP-CVT fluid used in my 2005 Altima 2.5
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
topnotchit
Hi everyone, I need some help.I went to my local "city garage" where one of the services was to replace my ATF oil. The last time I had it done, it was Max Life ATF. This time around, they replaced it with CVT Fluid. They told me they can use it in 2003+ altimas. But my owner manual says to use Matic-d. ( i suppose Max Life is a good enough equivelent). I called back city garage, and they said it is fine to use CVT.
May big concern is should I bring it back? Is CVT fluid ok to use in a 2005 altima (non-cvt car)? Can they really flush the old stuff out and replace it with the matic-d style fluid?
Is my car hosed? Thanks!
2005 Altima 2.5 SL with 125,000 miles
JunseiMotors
Car: 2010 Nissan Titan LE
2004 Acura RSX Type S - Supercharged
1986 Toyota AE86 GTS (hatch)
Im sorry but 02-06 Altima's did not come with CVT and that fluid should not be used. Use MATIC D or equivalent. Either that or they are gonna owe you a new transmission. I dont know why they used CVT. That runs close to $20 a quart.
Return to “3rd Generation Altima Sedan (2002-2006)”
