so i find this on another part of this site:
TM-105
DOWNHILL ENGINE BRAKE CONTROL (AUTO ENGINE BRAKE CONTROL)
When downhill is detected with the accelerator pedal released, the engine brake will be strengthened up by downshifting so as not to accelerate the vehicle more than necessary.
TM-111
WORK SUPPORT MODE
ENGINE BRAKE ADJ. The engine brake level setting can be canceled.
CONFORM CVTF DETERIORATION:The CVT fluid deterioration level can be checked.
Engine Brake Adjustment
“ENGINE BRAKE LEVEL”
0: Initial set value (Engine brake level control is activated)
OFF: Engine brake level control is deactivated.
CAUTION:
Mode of “+1” “0” “−1” “−2” “OFF” can be selected by pressing the “UP” “DOWN” on CONSULT-III screen. However, do not select mode other than “0” and “OFF”. If the “+1” or “−1” or “−2” is selected, that might cause irregular driveability.
so i call the dealership's service dept, he has no idea what i'm talking about! so i read the above to him, and he stutters even more saying i should ask my salesman! really?!??
i'm not at all happy with this.
