RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Wed Nov 21, 2007 7:42 am
The sr20de and det are essentially the same motor with a few differences. DET has lower compression, piston oil squirters, block is drilled and tapped for oil/coolant return, bigger injectors. You can turbo the DE, you will have to use injectors from the DET. You will also have to drill & tap the block for oil/coolant. Buy a manifold and turbo of your choice, FMIC & piping, downpipe & exhaust, upgrade clutch and engine management.
