onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Wed Dec 19, 2007 12:31 pm
I have a 95 with a redtop in it. I just changed out the water pump, thermostat, both hoses, and put a new aluminum radiator in it. I'm still running the stock clutch fan with shrouding too. I went for a few minute drive to see how it was, and it was past H on the stock gauge and at 210 deg. on my autometer gauge within 3-4 minutes. This isn't normal, my autometer would never go past 180 before.
When I stopped, my radiator and upper hose were both pretty hot. But the lower hose and my coolant reservoir were both still cold. What does this mean? Does that point to something specific that isn't working properly? I've got to figure this out, I need my car badly, please help!
Also, it's just a stock replacement thermostat, and instead of just and open hole that you center up top, it has a little ball/pin in the hole, so it wouldn't flow as freely. Does this mean anything? Thanks!
