Help connect iPhone5 to 2006 M35 Sport
Chris121
Car: 2006 Infiniti M35
Just bought this car and new to this I wanted to know what's the best way to connect my iPhone5 to play my music in my factory radio? What options are out there since there's no AUX or play music through Bluetooth.
moedawg140
Car: 06 M35 S (Adv. Tech)
LI Quad
G37 BBK with H&R DRS
(15mm F, 10mm R)
Focal 165KRX2 (F)
Infinity Kappa 63.9i (R)
Alpine Type-X 10"
JL HD900/5 (sub chnl.)
RF CPCD10-03
Morimoto 4,300K H11
Chris121 wrote:Just bought this car and new to this I wanted to know what's the best way to connect my iPhone5 to play my music in my factory radio? What options are out there since there's no AUX or play music through Bluetooth.
Welcome to the forum, Chris121!
A quick search of the forum (the Search button is to the upper-right of your screen) yielded this hyperlink:
want-bluetooth-streaming-in-your-m45-he ... ux%20cable
This will help you in your quest to play through the installed AUX of the USA SPEC PA15-INFI for iPod/iPhone integration.
Make sure to check in the back of the center console (center of back seat) to see if your car indeed came equipped with the RCA Cable (Yellow, White and Red) ports. You will have to press the button for the small console to open if it is closed. If those ports are there, you can use those for the AUX signal.
Edit: I have the iPhone 5 as well, and one cool thing that I like about the phone (not sure if other phones can do this, but I'm guessing yes) is that when it is connected to the car via bluetooth, whenever I press the mic/speech button on the iPhone 5, I can say commands to the phone via the mic in the car (not the phone itself).
Chris121
I have the iPhone 5 as well, and one cool thing that I like about the phone (not sure if other phones can do this, but I'm guessing yes) is that when it is connected to the AUX input, and connected to the car via bluetooth, whenever I press the mic/speech button on the iPhone 5, I can say commands to the phone via the mic in the car (not the phone itself).
Thanks!! I don't have those connections in the back...the Pa15-infi is aux and Bluetooth? I wouldn't need the isimple IS76 right? Because all I'm looking for is aux or bluetooth
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
Note: I edited the above quote (last paragraph) in my original post.
If you read #2 and #3 in the post I provided, it explains AUX and how to enable it.
If you read #4 it explains Bluetooth and purchasing the Anycom Bluetooth A2DP receiver.
I've never used the device, but it looks like if you want just AUX, use the PA15-INFI; if you want to be able to stream through Bluetooth, add the Anycom Bluetooth A2DP receiver as well.
Chris121
moedawg140 wrote:Note: I edited the above quote (last paragraph) in my original post.
yea I just noicted I also dont have a SAT button or Xm :confused: so I guess I have no other option then having to get bluetooth...
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
Since you don't have the SAT receiver in the back, purchase and install the USA SPEC PA15-NIS (install from your radio):
http://www.ipodcarpros.com/iPod/iPhone_ ... _info.html
BootyHunter57
Car: 2005 QX56
question
my M35 doesnt have nav or sat radio. do i need to use the USA SPEC PA15-NIS ?
if so what does it disable?
does it show ipod text and info on screen?
let me know! thanks in advance
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
BootyHunter57 wrote:question
Please read the post dated Nov. 5th, 2012 from myself (including the hyperlink I provided). Once you do so, you'll realize your questions have already been answered.
BootyHunter57
Car: 2005 QX56
just purchased this online. thanks!
LD1981
Car: 2007 M35
Have you had any issues with your car since you synced your iPhone 5?
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
LD1981 wrote:Have you had any issues with your car since you synced your iPhone 5?
Welcome to the forum, LD1981!
I have not had any issues connecting/syncing my iPhone 5 to my car, actually the connection rate when starting my car is currently 100%, as opposed to my previous phone (Droid Incredible) that had a connection-from-car-start-up rate of about 70%.
I will respond regarding your concerns on your other post: iphone-5-vs-m35-t568148.html.
Chris121
So my gf bought me a kit to connect aux for my car. I tried to install it and could not get it to work I tried everything "its only 2 plugs behind the radio" she bought me this kit http://www.icarkits.com/cars/INFINITI_M35_2006/ANIS3V9
im not sure if its the right kit but I put in my make and model and it came up for the one she bought me. Im not sure if she picked the wrong one but this other one looks similar but different price. http://www.icarkits.com/cars/INFINITI_M35_2006/PNIS3V9
im a little confused on the correct kit to get my car does have a CAT button which I have no idea what it does because when I press it a screen with a list comes up of stations but cant go any further then that I cant even click on a station. and I DONT have the RCA connectors in the back. Should what kit will work?? PLEASE help
EmDash
Car: '06 Black M35 with Tech Package, Brakemotive rotors, Tein H Techs, 19" Sport Rims
Hey Chris,
It looks like the one your gf bought you is for a system with satellite radio, and I think you're saying you don't have satellite:
Compatibility Notes:
Radio must have satellite radio support. Satellite radio does not need to be active or installed. This can be indicated in many ways, such as having a BAND, SAT, CAT, or XM button on the face of the radio. If you are unsure please contact us.
