pacman88 wrote:You have to get the fuel pressure out b removing the fuse and let it run until it dies and hold the throttle @ WOT
DAEDALUS wrote:If you don't disconnect the pump and/or injectors, the fuel being squirted into the cylinders will wash away the oil from the oil ring and your compression drops. WOT = wide open throttle. The butterfly valve has to be open to let as much air in as possible. Also, all plugs have to be removed.
brokeAs240sx wrote:Oops. I did mine w/ the throttle closed. I just let in crank 4 times. Got compression of 150psi each cylinder.
That's decent rite?. Yes, i'm a thread jacker.
