Help: Collant Replcement Q45
CJQ45
Car: 1997 Q 77k 03 Maxima GLE 19k
Hey guys
I drained and refilled the coolant in a 97Q. I mixed the coolant (70/30) with regular tap water.
Is this bad? Should I drain it out again and mix the coolant with distilled water?
My question is: is tap water ok or should it be only distilled water?
Thanks
Apparently the minerals in tap water can lead to early corrosion. I suggest buying one-gallon jugs of distilled water for 50 cents at Wal-Mart. Drain and remix.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I agree with Jesda (since when is he giving advice in IOL? :p)
On my old Q, i used water from a PUR water filter.....
