mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Wed Feb 13, 2008 6:53 am
I don't think our ECU's can really learn anything. They simply have a fuel and ignition table and it bases how much fuel and ignition it gives to the engine on RPM and essential load (which is based off of other inputs, I believe being, the MAF, TPS, and possibly a few others... maybe speed sensor and something else).
The ECU can't change the maps itself so it simply sees X amount of air coming in at X rpm and injects the correct amount of fuel based on where those two essentially meet on the table.
All resetting the ECU will do is remove any error codes that are stored in it, if there are any.
As for the thread in the Maxima section, I actually just left it and locked it for future searching reason. In case any other 3rd gen guy goes through the Maxima section looking to solve the same problem, he'll have the link to potential answers in here.
Its always hard for me to figure out whether to put a thread like this in the car section or engine section so since there was one in both I figured I'd leave them just in case.
