help coilovers noise
extreme
Car: 89 nissan 240sx- 92 240sx
i install my coilovers today (ksport) and something i notice i s a noise when i turn the wheel sounds like when a spring tension is release any idea what can be
thanks in advance
gumby74
WTF???? Squeaking, thudding, rattling, boioioing?
extreme
gumby74 wrote:WTF???? Squeaking, thudding, rattling, boioioing?
is more like ttboinggg
Kckouki
Car: '97 Nissan 240SX
Its probobly the K-sports
gumby74
I was kinda kidding about the boing....
Razi
Car: Moo
But I don't think he was kidding about the ttboinggg
zenkii
Car: 95 240sx
OK, already know you problem because i too had the same problem on my megan coilovers....i actually posted the same topic as this but just got to find it in the search system
zenkii
Car: 95 240sx
Here yeah go dude,
zerothread?id=229052
you can offer me help service fee on my paypal account
kazama
Car: 1993 240SX SE
Well that's y u go JDM, never trust taiwan or china nor US made parts
extreme
zenkii wrote:Here yeah go dude,
that happens rigth after i install the coilovershow can find if mines are blow ?
9sec240
Car: S14.5 Turbo KA
The pillowball in the top of the strut is not doing its job.
Your suspension is supposed to rotate on the pillowball like a bearing. Its not turning so instead the spring is slipping in on the perch making that sproingggg noise.
Turn your wheel and watch the nut in the center of your front strut plate. If it rotates when you turn your wheel, everything is good. If it does not rotate, then you have an issue. Usually you can lube it up and get that working again.
tu_bryan
Car: None =(
i see your problem, yer out of coilover fluid... jk
extreme
9sec240 wrote:The pillowball in the top of the strut is not doing its job.
your where rigth the top nut was the problem i loose it a little bit and now is noise free thanks
9sec240
Car: S14.5 Turbo KA
Always happy to help.
Keep that pillowball lubed up so it continues to work well.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
kazama wrote:Well that's y u go JDM, never trust taiwan or china nor US made parts
-ExCesS-
Car: 00 Sentra / 95 240SX
Bumping this because I have the same prob.
Should I loosen the top nut or can I spray it with WD-40?
I <3 search button
E7-S14
Car: ess 14 foo!
Am I the only one on here with megan coils that doesn't have a problem with them?
on a side note.. i finally beat on them briefly to test em out...cranked up the dampening to 7front and 10 rear...(megan terms for stiff as f***) my car felt solid while i was attempting to drift.. smooth going in and out of a slide..everything was perfect.. except for my skill.... i would recommend these coilovers to anyone and everyone..
sry for thread jack. i had to tell someone..
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
I have megans also...with no problems, just some squeaking. mine are set to 10front and 7 rear...I have mine softer in the front for less understeer...hopefully
E7-S14
Car: ess 14 foo!
martins_240sx wrote:I have megans also...with no problems, just some squeaking. mine are set to 10front and 7 rear...I have mine softer in the front for less understeer...hopefully
a +- 3 interval prob wont make too much of a difference think about it.try 10 front 20 rear..but then it might be a lil bouncy in the rear..compared to the front
-ExCesS-
-ExCesS- wrote:Bumping this because I have the same prob.
I <3 search button
Anybody? I searched a bit more and saw a thread saying not to mess with the nut so I dont wanna loosen it, but is WD-40 enough of a lube?
martins_240sx
dont you mean 20 in the front and 10 in the rear...since it gets harder the closer to zero....correct me if Im wrong but wouldnt you want it harder in the rear so that there is less understeer and with a rigid rear you would get a better slide....?
94_240sx
Car: 94_240SX
I have Stance GR+ Pro and it makes noise when I turn. I put front wheels up in the air and no noise. I think I should lube up the pillow ball mount and see what happens. The noise wasn't there when I first installed them though.
-ExCesS-
94_240sx wrote:I have Stance GR+ Pro and it makes noise when I turn. I put front wheels up in the air and no noise. I think I should lube up the pillow ball mount and see what happens. The noise wasn't there when I first installed them though.
same, what lube are you using?
E7-S14
Car: ess 14 foo!
martins_240sx wrote:dont you mean 20 in the front and 10 in the rear...since it gets harder the closer to zero....correct me if Im wrong but wouldnt you want it harder in the rear so that there is less understeer and with a rigid rear you would get a better slide....?
yeah thats right..my badI mis read your posttook understeer for oversteer.. lol just glanced at it ..yeah i completly misread your post
but yeah my method
what i meant was since you want less understeer try mor than a +-3 interval.. it will make more of a difftence..so yeah 17front and like 10 rear..makes more sense
94_240sx
Car: 94_240SX
I don't know. Maybe WD-40? Guys, what should I use????
babowc
Car: 240sx
LOL.This proves it..NICO members =/= basic suspension informed.
Add more preload.Add enough so the spring is on there pretty tightly.Dont forget to hammer down your perches.That'll be it of the noise.
94_240sx
Car: 94_240SX
babowc wrote:Add more preload.Add enough so the spring is on there pretty tightly.Dont forget to hammer down your perches.That'll be it of the noise.
This makes more sense. I have no preload at all. I'm still learning about all this suspension stuff. It looks like noise is not going to hurt anything, so I'll take care of it when I jack up the front of my car next time. Thanks for the info.
-ExCesS-
hmm, 9sec240's description seemed to make more sense in my side. Noise only comes when I turn the wheel. Just gonna spray my pillow ball with WD-40.
94_240sx
Car: 94_240SX
-ExCesS- wrote:Just gonna spray my pillow ball with WD-40.
I'll try this as well tonight. Little bit of WD-40 shouldn't hurt much I guess.
94_240sx
Car: 94_240SX
94_240sx wrote:I'll try this as well tonight. Little bit of WD-40 shouldn't hurt much I guess.
Okay, I just put ONE drop of WD-40 on the pillow ball joint and noise is completely gone. Can't believe it was that simple to fix it. Yeah, I think it was a pillow ball joint. I have Stance GR+ Pro. I think this is what's been happening to me.
zerothread?id=276053
