chickentendah »
https://forums.nicoclub.com/chickentendah-u11049.html
Tue Sep 20, 2005 6:25 pm
WARNING: LONG POST; ANY HELP IS GREATLY APPRECIATED
Before I brought in my car for a clutch replacement, I had the following setup:
nismo ss clutch line (eliminated the loopy box)exedy stage 1 oem replacement clutch kit
I did not experience any problems with this old setup (up until slippage due to end of disc life).
Since it was time for a clutch change, I went ahead and had the following parts (all brand new) installed:
nismo slave cylinder (installed for peace of mind)act "heavy duty" pressure plate (street grade)act street discnismo clutch fork pivotOEM sr20det throwout bearingOEM sr20det pilot bearingOEM sr20det rear main seal(flywheel was resurfaced as well)(transmission fluid flush)(clutch fluid flush)
The first time I pulled the car out of the shop, the clutch behaved very strangely. The length of the clutch pedal travel was extremely short. The pedal was very soft. The engagement point at the pedal was very close to the floor. I managed to drive 3 miles like so. As I did so, I noticed that it became progressively difficult to shift gears with the shifter----kinda like trying to shift gears without fully pressing a clutch pedal. Finally, I could not shift into ANY gear whether or not my left foot was pressed to the floor.
I started to wonder why my pedal throw was so short, and I decided to yank the pedal upwards with my hand for the heck of it. After pulling up, the pedal SPRUNG back up to normal clutch height. Then, I was able to drive normally without any shifter problems.
Since then, the clutch grabs and shifts through the gears silky smooth. However, my transmission now randomly pops out of 4th gear whenever I'm coasting along in the low rpms (up to 2000rpm). The poppage is more likely to occur whenever I take my foot off the gas pedal as I'm coasting to a stop in 4th gear. It has popped out twice under light acceleration in 4th gear.
My mechanic and I first believed that my clutch hydraulic system was screwed up. So, we bled the crap out of the clutch system numerous times. No difference. So, we replaced the Clutch Master Cylinder. No difference. My mechanic says that I'll have to take out the transmission again to see what's up, and that the ACT pressure plate is one of the first suspects.
I don't want to change the pressure plate only to find out that it isn't the problem.......My car never popped out of 4th gear prior to the clutch service, so I highly doubt that my transmission itself is going out.
What do you guys think?????
BIG THANKS IN ADVANCE
