HELP!!! clutch problems..urgent
x240xdrifter
Car: 1991 Nissan 240sx
firrst off I have a 89 240sx, ok so I've had my fair share of clutch problems in the past. when I bought the car the kid told me it had a brand new oem clutch installed 500 miles before I bought it, I had to swap the engine cause it blew so I got to verify if it was new which it was so I reinstalled that along with the slave cyclinder. I also took out the damping box and repaced the hardline. so this is where my question comes in, the other day when I pressed in my clutch pedal I get this horrible moan, but it goes away when I depress it, what is going on? it sounds like its coming from the clutch master cyclinder but can that be possible? I need help soon cause this is my only car and I need it as a dd, thanks guys
180fan
Car: 89 fastback
sounds like your clevis pin needs some lube.
x240xdrifter
where is the pin? how do I fix it? am I screwing anything up?
180fan
Car: 89 fastback
it's the pin that's got that weird bobby pin lookin thing through it where the master cylinder's U shaped bracket meets the pedal. Put some lube on the clevis and pray the groan goes away.
