For your 25, I'd look into a GT30R or GT35. Check out
http://www.atpturbo.com and give them a call with your needs. With what you are running I'd lean toward the GT35 b/c the output/powerband you are looking for vs. it's flowrate.
I'd consider the 30R if you could give up some power (maybe 400'ish rwhp instead of 450) for spool. Give the guys a call over at ATP... they'll help you with which way to go and not give you a sales pitch (from my exp).
Make sure you take care of fuel delivery (didn't see that in there) and look into lowering your CR so that you can hit the boost levels you may need to make that power (bigger turbo will provide more power with lower boost levels... but it will be a trade for more lag obviously). Hope this helps!
There is a good VG30 w/ intercooler for 400 on ebay... I'd jump on it if I hadn't found this T3/T4 I have. Not trying to be a prick, but it really gets confusing if we start talking about turbos for the 20 and 25 in the same thread... so if we could keep this on on the 25 that'd be great.
