Help choose offset (been searchin)
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Will be getting Powered By Max coilovers on my S13 this month. Was looking to upgrade wheels, came upon the Work VS XX 18x8.5 (4 lug)
Offset Choices (leaving out ridiculous options)
+7 (3"+ Dish )+19 (3" Dish )+32+45 (2" Dish )
I got these from Work's website http://www.workwheelsusa.com/m...F.pdf
Felony Performance Lists many offsets but also says below that they can do custom options so I assume there extra offset choices over the Work page are part of the extra options they can supply http://www.felonyperformance.com/vs-xx6.html
I used this offset calculator http://www.1010tires.com/WheelOffsetCal ... .aspIncase it doesn't have i filled out under current wheel specs enter stock size: 6"s Wide and 40mm Offset.
The +7mm would stick out 65mm, around 2.5".
I don't mind rolling and pullin fenders but would this be too much? the +19mm seemed more reasonable. I don't mind a small streching of tires to fit. I also don't need my car slammed it will be stiff enough for drifting but I would like it about 2"s lower then I am on stock shocks and S-Tech's
Modified by TimTurboZ at 8:46 PM 6/1/2009
r3v_v3ng3
Car: 91 fastback ka-t
i got +17 7x9 right now with a roll and pull on the fender is still able to put a 11mm spacer so technically its +6. so the lower the better imo
