tungaz »
https://forums.nicoclub.com/tungaz-u230699.html
Wed Feb 05, 2014 9:32 am
I changed the plugs to the NGK Nissan branded plugs from z1, I lined up the tbelt marks with the marks on the cogs, and didn't pay attention to the marks on the backing plates. When I set timing I'm using the thick wire from cylinder 1, letting the car warm up fully so temp gauge is showing about halfway, and rpm is below 950. The best results I've gotten are showing 30° btdc, the car runs very smooth under normal driving but maintaining speed in high gear is very jittery, also it has started taking its time to fire up, today it started up fine but while I was sitting at a light it stalled(has a 6puck clutch which I'm not too familiar with yet...) And wouldnt start back up, I fiddled around with the ptu harness, cranked it for a solid 15 seconds while giving it some gas and it started up again and got me to work without issue... So I'm pretty thoroughly stumped. BTW it does have dual pop charger but the ecu is chipped for it and I've done the flower pot mod so I don't think that's the issue, also the injectors appear to be original though I did listen to each of them and they are firing and sound pretty strong.
