180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Apr 21, 2004 9:25 am
Well if you're gonna take the engine apart, do it like this.
1. remove lower oil pan2. remove baffle around oil pick up3. remove upper oil pan4. undo the 6 bolts holding the back piece that has the rear crank seal5. get a screw driver and push from the back of the oil seal6. tap in new seal
