HELP Car wont start :(
Kaioshin1982
Car: Not a 240 =) Thinking of getting one again...
I already posted this in the tech section and I'm sorry for posting here also... But I really need to fix this problem as the car is my daily driver to go to work and back..... If a mod feels that this should not be here, please delete this thread. But I really need help
I was driving around and turned the car off and now it wont turn back on. The car would not even crank, the starter is good since I tested it by giving direct power to the battery to the starter. I have no clue what it is.... I thought it was my alarm so I disabled my alarm but still the same thing. When I turn the ignition, the temp gauge goes up to normal but nothing else works. Lights dont flick or anything. Just doesnt crank and dont start.... PLEASE HELP!!!
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
have you checked all your fuese, if the ECU fuse is gone it wont crank, other than that, check the battery connections, and ground straps
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
When you give direct power to the starter from the battery does the starter turn over, if not then i'd double check the starter
Kaioshin1982
When I give it direct power to the starter while having the key turned to ignition, the car will just start so I dont think its the starter.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
then like hybrid_flyer said, check the fuses
Kaioshin1982
stupid question... how would i know if the fuse is good...
hybrid_flyer
look at it closely if the metal inside is broken then its bad, if you have an ohm meter check for continuity. if its infinite then its open (BAD).
e1_griego
Car: 89 fastback
I had a stupid problem where the wire to the starter was crimped to the point that the starter couldn't get direct current. Replaced the starter and still didn't start and finally jiggled the wire a bit and she fired right up....kinda lame but it worked for me.
Alex
Kaioshin1982
Hehe.... where is the ecu fuse... ok you all can laugh at me....
