doctah-jay »
https://forums.nicoclub.com/doctah-jay-u137264.html
Sat Jan 23, 2016 5:11 pm
Hey guys,
My cars a 1990 240sx with a 1992 ka24de motor. for the past month it has been having problems starting, i would need to turn the key maybe 3 times before it turned over. When i was working for a local mechanic i asked him if this means i needed a starter and he said yes. I had it sitting for about 2 weeks and it was dead. Tested the battery and battery was at 7.4 volts. figure might as well get a starter and battery and do it in one go. So got a jump, got everything and went to work. Got everything done and went to turn the key and there is one loud click. All the lights are on and everything is tight. Iv been searching and the 2 things that seem to come up, is the ground cable under the battery could have corroded and needs to be put in a new spot, or that the ignition switch is bad and that i need to buy a new one. I tested the plug that goes into the starter (the one with the really skinny wire not the thicker gauge that bolts on) and when my friend turned the key it said 11.4v. Im not sure if that means there is resistance or if maybe i tested something wrong.
Please help!!
