help car wont start!!!
unanswerred
Car: 1991 240sx hatch, 1995 240sx SE shell
ok so i went to do the infamous timing chain guide removal on my s13. all went well until i had everything back together and realized i hadnt set it at TDC before i started. i tried starting it the way it was. didnt start. so i set it at TDC. still woudlnt start. i also tried advancing and retarding the timing via distributor and still wouldnt start. what do i do now???
onosqv
Car: '92 240sx Vert
you didn't set it to TDC correctly. factory service manual is your friend.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
To check your cam timing, first disconnect the ignition coil wire, remove all the spark plugs and remove the valve cover. Have someone tap the starter while you have your thumb over the #1 spark plug hole. Once you feel compression, insure that the block timing pointer at the front pulley is pointing to the zero mark on the pulley. Remove distributor cap and insure that the rotor is pointing to #1 firing position. The #1 piston is now sitting at TDC compression stroke. Remove the upper and lower timing covers. Now look at the lower timing chain for the chain mating (silver) mark which should be at the crankshaft sprocket gear mark. The top end of the timing chain mating (silver) mark should be at the large idler sprocket gear mark. The upper timing chain mating (gold) mark should be at the small idler sprocket gear mark. The other two chain mating marks should at their cam gear marks.
unanswerred
thanks for the help. i was using tdc for the exhaust stroke not compression haha.
