hairetsu »
https://forums.nicoclub.com/hairetsu-u49974.html
Mon Mar 19, 2007 12:41 pm
if the car isn't startingit you can narrow it down like this,
First, check to see if the starters good, when the car is on a lift, you can ground the starter wires together to see if the starters getting power/is good.
If the starter cranks, and the engine starts up, you are getting power to the starter, and should look under the steering wheel in the dash, and check the wiring down there prolly that, if all the wiring is good there, then you're ecu is left to cause, also make sure the ecu is plugged in all the way, it may seem it is, but sometimes it needs to go in a little more
