Ok, I have a 89 coupe, all stock. It is a 5 speed. I had issues for a while about it being hard to get in gear, fixed a leaking slave cylinder, adjusted the clutch pedal, and it was fine.
Two weeks later I was driving to school and when it came time to leave, no reverse. Not even a grind. Solid like a rock. Every other gear went in perfectm reverse was just not there. I drove the car home and it was ok. I stopped on a hill, it went in reverse. Got home, it would not, and still wont.
I changed the bushing. I bleed the system again. I have not adjusted the clutch pedal again because it goes in every other gear fine.
So is reverse just gone? I tried rev matching it. Tried easing off the clutch and going in gear, it wont even grind or try.
Any help greatly appreciated!
