DPEXi »
https://forums.nicoclub.com/dpexi-u102245.html
Fri Aug 22, 2008 4:12 pm
Okay, I've searched around countlessly, and eventually to the the point where my internet browser isn't letting me search anymore (lol). With that said, here's the story, and I'll be as detailed as possible.
I have a 1989 240sx Coupe, 5spd, 205k KM's.It's bone stock, and as you might know, I don't have to push the clutch down to start.
Here is a list of the things:- New starter- New battery- Fuel injectors are good- Plugs are good- Plug wires are good- Distributor is good- Just had an oil change
I've had the car for a month. It was sitting for 2 years from the previous owner.
The first 3 weeks I've driven it, it's driven well. Starts up fine, until the starter went around week 2. I had that replaced, and it started fine as usual.
During the beginning of week 4, the car would struggle to fire up in the beginning of the day (first time starting after a long night of rest). I would turn the car on, but it would only crank. This would happen about 2 to 3 times, then on the 4th try, it would fire up, like nothing had happened. It has the usual "cold" idle at 1500RPM, then drop to normal; 750RPM.The car runs perfectly after that. Every time starting it after the initial fireup of the day would be perfect.
However, throughout week 4, these symptoms have been getting worse. Same thing would happen. I'd go to my car in the morning and start it up, and it wouldn't fire up. It would only crank. The amount of times it would take to fire up increases from 2-3, to 4-5 tries. On the 4th or 5th try, the car would fire up; again, to it's usual "cold" idle at 1500RPM (roughly), then drop.
Although this time around, the idle would drop below perfect, relatively quickly after the 1500 "cold" idle. I would give it gas, to keep my RPM's up, and it would fight through this "puttering" stage and continue the "cold" idle. After this, the car runs perfectly as it usually does throughout the day.
So now it's the end of week 4, and my car isn't wanting to start up. Same thing happened: I woke up in the morning, went out to start my car (took about 4 tries) and then it fired up. No problem. I drove to a store to grab an oil filter for my next oil change, and when I was about to leave, my car wouldn't start.
I noticed that the fuel pump did not "prime." I checked the "Fuel Pump" fuse and it was good. So I tested my fuel pump, and it was dead. I replaced it with an OEM one on the spot. I tried starting it, and it didn't want to start. It cranked, but no fire up.
In addition, the "Fuel Pump" fuse under the hood next to the battery, was blown. So I had that replaced with another 10A fuse. I tried starting it, and it did the same thing; 3-4 cranks, and the 5th time it fired up. I let it idle for a bit to let the new fuel pump do it's job. I decided to turn the car off, and try to start it again, but it didn't want to. It would crank, and then sounds like it's about to fire up and dies instantly (reaches 700RPM and shuts off within 1.5 seconds). Again, it blew the 10A fuse, so I put in a 15A. It hasn't popped. I gave up and went home to research.
So today, I checked to make sure my fuel filter was okay. I pulled one of the hoses from the filter, and turned the key to "Accessories." Fuel came out as it should, so I ruled a faulty fuel filter out.
The next thing I checked, was my MAF. I unbolted the 4 10mm nuts from the air intake box, and it was immaculate. I thought I wasn't getting any air, so I left the MAF unhooked from the air filter. I tried starting the car, and the car fired up instantly to the usual "cold" idle. It was at 1500RPM and then died instantly.. I tried to save it by pushing on the throttle but it wouldn't let me. It continued to drop, and eventually, shut off.
I tried to start it up again, and it would do the usual "crank-fire up to 700RPM-then die" within 1.5 seconds.
My spark plugs are good, as they aren't soaked from fuel.My injectors are good, but one of them might have a bad seal, and it spews just a little bit of gas when I push it into the motor away from the rail. My wires are relatively new, aswell as the starter and battery.
I thought it could have been a relay in the fuse box next to my battery, specifically the "EGI Pump" relay. I don't know how to check if it's faulty, but it sends fuel throughout my system so I assume it's okay.
I don't know what it could be and I'm hoping you guys could help me. Thank you
