Help! Car stuck at 5psi, and its slow! plz read
ulti
Car: 1990 240sx hatch, sr20det
So i just picked up my sr powered 240 on friday, when i bought the car it wasnt boosting properly but it runs great, just pulls like an N.A. car. Anyways i hooked my boost gauge when i got home to see whats going on, i do hit and hold 5 psi but the car feels gutless. i checked timing and set it to 15*.i dont know much about the car yet. it has stock sidemount IC with the recirc valve bypassed. Im new to SR20's but not turbos, please help me diagnose this I want my racecar!!! :mad:
ghost_22_47
Car: 1993 Nissan 240sx Covertible with RB26dett
2004 Audi A4 1.8T Quattro
Maybe a stuck wastegate
ulti
ghost_22_47 wrote:Maybe a stuck wastegate
Good thought but its not likely considering a wg stuck open = no boost. And a wg stuck closed = tons of boost
BCNR13-specD
Car: 1985 mercedes 380se
it could be stuck half open. half open = 5#. but maybe crack, hole, or loose fitting on piping/intercooler causing pressure leak?
nissan_star
Car: 2000 maxima se and 1993 240sx vert (5sp!!!)
Did you actually check and reset your timing? I had a similar problem recently, my timing was off after I took my head off because I must have bumped the CAS when I installed it, set it right again and it is fine. If you have a vacuum gauge check to see if you get around 19 or 20in hg vacuum while at idle.
EnjoiNismo
Car: 93 240sx
BCNR13-specD wrote:it could be stuck half open. half open = 5#. but maybe crack, hole, or loose fitting on piping/intercooler causing pressure leak?
:werd:
Check all your fittings on your intercooler and all vacuum hoses you have hooked up.
ulti
i put on a fmic and all new piping, but after about a day of driving... think my maf took a crap. its at the shop rite now, they are diagnosing it as we speak
