ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Mon May 31, 2004 11:51 pm
The IACV could cause your idle to jump around, and dip low when you put your clutch in, but it won't cause your engine to die right after you start it. Check to make sure you TPS is plugged in, it controls your idle. When it's working properly, it adjusts your idle to keep it around 750 rpm. If it's unplugged or not working properly, and your idle is set too low, it could die right after you start it. However, you most likely have a massive vacuum leak. Just look at all your vacuum hoses, and see if one is split, broken, or has come off. I give it a 95% chance that's your problem.
