spooled240 »
https://forums.nicoclub.com/spooled240-u54828.html
Sat Dec 29, 2007 9:37 am
you know this is kind of what i expected with your problem: I think that you have an air leak (vac still reads 20?)
Because i think that when your engine is in vacuum, it's sucking unmetere air through some leak or whatever and making the engine run lean at vac.
When boosting, the boost is probably leaking out the leak creating less air in the engine thus making it run rich under boost.
I know you checked for air leaks and what not and your vac. reads 20, but try again to find the slightest leaks..maybe a blown/cut coupler, blown gasket somewhere? I think that there is probably a small leak somewhere that doesn't affect the reading of the vac gauge but greatly affects the driveability of the car.
