help car's overheating
THAIGER420
Car: 1991 Nissan 240SX SE
i searched but came up with no results. i replaced my water pump, thermostat, and radiator and bled the coolant 3 TIMES. the car won't overheat when its idling but as soon as i drive after 15 minutes it will overheat. also i noticed the top radiator hose will be warm and the bottom one is cold. i made sure my fans work and i check the oil everyday just in case it is a headgasket but it doesnt seem to be. can somebody please help i know 240's are notorious for overheating.
BIGTIMER_240
Car: 1989 240SX ka24de
i had exactly the same problem till i drove it hot and blew the engine, it was a ka24de. know i role with a ka24e with three fans im so scare of the needle know, it dosent even get hot it stays between cold or a mark so im good. oh and is the shroud fa and 2 e fans. i dont know what to tell u take it to a mechanik before something happens.
Two-Fortee
Car: 180sx.
Head gasket maybe....Was the coolant green when you drained it? Have you done a compression check?
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Did you replaced the radiator with a new one...The bottom hose should be sligthly warm, if not , then you might still have a clogged radiator. Is this overheating related to heater usage ?? Maybe a clogger heater core ???
SR24DET
Car: RMS13
When it starts to over heat, try turning on the heat and see if that helps
Crautz240
Car: 92 240sx Hatch
Sounds like you need a new radiator if only one hose is warm.
miracleboi123
Car: 93 s13 coupe
yep; i would think you need a new intercooler/fluid. make sure your headgasket is not blown like mine. in mean time if your just driving around just if it overheats; turn the heat on. i heard tahts what a lot of pro racers out there do.
IDRFT95S14
Car: 1995 Nissan 240sx SE
even tough you changed the thermostat it still could be faulty i went through three at one time, now let me ask you ,when it first overheated did you notice anything or heard anything reason why i ask because mine started with a tiny rad leak overheated the car didnt notice temp rising and then i heard small clanking sound i bent a few of my valves had to tow my car home, the next day i crank it up 10 minute warm up temp look ok so then left, about 15 minutes later it overheated i dint know about the valves till i took the head in to get it checked i imagime that was that sound it made
hakosuka86
Car: Toyotas Nissans
hmmm I was using the search and notice this one.i have the same problem BUT i have a new radiator its weird though i be driving for 8 mins and so i pull over and my resevoir its empty i add water, temp goes abit down keep driving home when i do turns it seems the temp goes a bit lower.>.>the only thing i seen that concerns me=the fan its a lilbit wobbly i can move it with my hand a bit but its bolted down good! so then???? por favor ayudenme!
hakosuka86
i heard we have to pressurize and bleed the system!!!
THAIGER420
i also noticed when i do turns it cools down a bit and the heat inside the car doesn't work like it used to. i also noticed sometimes when i drive the temp will shoot up then drop back down a little. is it possible my parts are bad after 3 months? the parts i have installed are nissan oem water pump and thermostat from http://thenismoshop.com and a mishimoto radiator
amolao
I bet you still have an air bubble somewhere in there. The KADE is very sensitive when it comes to bleeding the cooling system. Are you loosing coolant from your reservoir after parking the car?? You need ALL the air out and a functional coolant reservoir to get good pressure and flow. How is radiator cap ?? Can you push on the spring easily ??
hakosuka86
mines kinda soft on the rad spring. and yes my resevoir was empty!!
when i turned it on to go backhome from work it was sputtering alot n my idle was rough so still bubbles in there i guess.
how is that done wat i did was:
open rad cap and manifold bolt run it and the pour sum coolant on the rad wait......then close rad cap n then bolt.
im going to try it back wards close bolt first then cap.
hakosuka86
the sputering continues i changes spark plugs and still does it.its not heating up, but engine its sputering now just happened over night!
could it be cold engine start plug or fuel filter???
any ideas guys??
RR240SX
Blown head gasket probably. Have a shop near you CO test the radiator. I had the same problem. When the car is at idle there is not enough compression leaking into the cooling system to create an overheating problem. As you drive excess compression leaks into the cooling system that creates an air bubble at the thermostat and the thermostat remains closed. Your coolant isn't circulating that is why one hose is hot and the other is cool.
These motors can be a ***** to burp but usually once the T-stat opens the first time the system burps.
