DriFt3r wrote:i think i will check that today...I was also reading and someone else said something about if the engine coolant temp sensor or the primary O2 went bad then it would do the same thing....have you guys have any experiance with this?
I *think* I have a bad coolant temperature sensor. AFAIK (Chris can confirm this, I'm sure) there are two sensors on the KA24DE for coolant temp. One of them (closest to the engine block) only sends a signal to the temp gauge on the dashboard (it doesn't really *do* anything) the other sensor is also on the intake side but nearer the passenger side of the car (this one has a red plug and communicates directly with the ECU).
Chris, can you confirm that I'm correct here?
Anyway, the symptoms I'm seeing are hard starts after the vehicle is warmed up. It seems that the ECU thinks the engine is cold and dumps too much fuel in at start-up. I'm probably running rich after startup too.
Running rich can kill an O2 sensor. I also had that problem, which manifested itself in hesitation between 2500-3000 RPM. Changing out the sensor (only one, have an OBD1 engine) fixed that problem.
