chrissa »
https://forums.nicoclub.com/chrissa-u9545.html
Wed Mar 26, 2003 11:10 am
Have any of you guys with this overheating problem ever checked to see if dirt and crap is blocking the airflow through your radiator? This is especially important with people who have air conditioning.
240SX's with A/C have two full size radiator cores, one in front of the other. The A/C core is in front. My car has slowly been getting hotter over the years. I always thought it was the engine wearing out.
Just this last weekend I did the timing chain and pulled out both radiators to have some room to work (and to get rid of that A/C core completely - I need an extra heater, not A/C where I live). To my horror, I found that 60% of my cooling system radiator was completely blocked with dirt, fluff, crap, and a bunch of other stuff. The A/C radiator was fine. Stuff had gotten up in between the two rads and plugged the back rad. You can't see any of it when the rads are mounted in the car. From the back, the cooling rad looked fine, and from the front, the A/C rad looked fine. Most of the blockage happened on the top half of the rad, right where it's buried up in the car where you can't look though it to see.
I simply leaned the rad up against the side of the house and very gently sprayed water from the back through to the front. Be sure to aim the water directly at the rad fins, and not at an angle, otherwise you run the risk of bending the fins with the water pressure. If you bend then, then you get the pleasure of straightening the fins which can take forever. I washed out about one good sized fist full of dirt.
No problem now. The car hasn't run this cool in a long time. One more thing to check for before you replace something like a head gasket.
