onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Thu Jun 14, 2007 8:35 pm
I put almost 6 qts in, basically what the fsm says. Used a half bottle of water wetter, 70% water, and 30% coolant. When I squeezed the top and bottom hose, they were pretty hot, I could hold on, but it was still hot, just like the valve cover. So, if I the hoses/radiator are cold to the touch, that means the water pump isn't working? That shouldn't be the case, since they were pretty hot to the touch, so it must be pushing just fine. I'm still running the usdm radiator, but I should probably have an sr20 radiator huh? Do they flow better then the stock ka radiators?
Driving the car home tonight, there wasn't a single problem, didn't even get above half, never tried to overheat. This leads me to think it's just the gauge screwed up. If there was a problem, the car would overheat constantly wouldn't it? Anyways, thanks for the help, any more input would be great!
