VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Dec 31, 2020 6:14 pm
I don't see a security lamp and cranking sounds healthy, so the battery or connections aren't likely culprits. First find out if it's fuel, that's the easiest thing to check. Pop the air filter cover and spray some throttle body cleaner, Brakleen, etc, down the intake. Basically anything combustible. If it starts and then dies again, it's a fuel problem. If it doesn't start, get a code reader and see if it's throwing any DTC's. If there's nothing obvious, pull a coil and check for spark and make sure there's no junk in the mass airflow (MAF).
