Help Car just died...wont crank or anything...HELP!!!
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
So i went to the grociery store to buy some meat for grillin and when i got back my 95 zenki wouldn't start...wtf!? Not the battery because my radio and windows still worked...not a fuel problem because if it was it would still crank...so i'm guessing its the starter? ANy guesses? I appreciate all the help i can get...Thanks. It's never done this before...i gave it a rolling start and still nothing...not the alternator...
mattscar
Car: 1989 240sx, 1992 Miata
This is the same exact problem with my corolla, Mine is a grounded wire somewhere in my wiring harness, but I am still following the wire.
RunCool
If i were you a would try to jump, even though you already tryed to pop start it, and if it still doesn't work, check for grounds, finally bench test your starter. Postive and solenoid, neg on starter, and jump the"S" terminal, if it works its not your starter.
WI_S14_Goldie
****ed up thing is it started today...after i got it towed to my house! GAY!!! there's a wierd winding noise coming from the starter so i'm guessin its goin bad...any more help would be appreciated...i guess its time to replace the starter...
