Help car dies while at stop lights..need mechanic advise
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
Alright its not my 240 its my beater, a 93 toyota camary. It dies while i'm at stop lights...i was hoping some of you more advanced mechanics could help me pin point the error. I was thinking it might have something to do with the fuel...injectors? Fuel pump? Any help would be appreciated...Thanks.
vancouverbc
Car: 1991 240sx
clean your throttle and iacv(if you have one).
WI_S14_Goldie
would the throttle body have anything to do with it though?? Anyways i'd appreciate anymore help...
vancouverbc
Car: 1991 240sx
clean the throttle around butterfly valve. also spray carb cleaner in while engine running . whole container. this is the first thing to do when you have an idle problem. its not your injectors or fuel pump.
Dieselman
Car: 07 Ram 3500 Cummins Diesel.
If that dosn't do it look for a vacuum leak. A cracked hose can screw up your idle in a BIG hurry.
Cyclemut
Car: 2002 Xterra 4x4, 2005 Frontier 4x4
Is it an automatic? Does it do it all the time? Or only after driving a bit, like when it goes into overdrive and then you come to a stop? Some more information may help here.
WI_S14_Goldie
Yes its an automatic...it does it every once in a while...not to mention its leaking coolent too. I'll replace that soon....
Cyclemut
Sounds like an overdrive solenoid sticking in the transmission. Might have the transmission flushed, with a positive displacement unit, using BG transmission cleaner and additive. If the solenoid is sticking, then it won't unlock the torque convertor, stalling the engine when you slow down. GM was real bad about that as well. If it was dirty throttle body, I would think that it would happen more often than not.
